Switch from aerial to Satellite
  • Sad 1
12 answers to this question
You have to switch via the tuning page - sat or antenna - the selected option becomes your TV input
if watching one cahannel after switching, then the back button does take you to the previous one even if on different input,   so can switch easily backwards and forwards between current and last and back again
I have the same problem, the easier way is to Open the channels list using List button, then on the top right there is a filter button, there you can switch between Antenna and sattelite.
I like to recommend to LG add this feature to merge channels list or doing similiar things, for example I have added my favorite antenna channels to Favorites 1 also added my favorite sattelite channels to Favorites 1, so when I press Favorites 1 I assume list both types.
Anyone knows if this feature is going to be implemented in a software update? Surely it's not that difficult if even cheap combo boxes have it.
When watching a programme via aerial long press 1. Set the channel to quick access 1. Next switch to a satellite channel and long press 2 and save it to quick access 2.
Now if you long press 1 you are in aerial mode and long press 2 satellite mode.
Exactly, I really don't know why LG hasn't made the menu this way, it's so necessary and obvious. Actually I regret that I didn't buy a Samsung TV instead, because its menu is more user-friendly and easy to use. I've bought this TV for my mom and she hasn't been able to change between "Antenna" and "Satellite'' even once, because it's too complicated for her.
I partially solved the issue by simply having terrestrial dtv channels and satellite channels chosen as “My channels”  in the home menu.
I don’t have to go to settings everytime to switch.
It isn’t a problem unless you crave watching every single channel on satellite and terrestrial tv.
It is useful to have a selection of favorites.
For anyone still looking for a workaround here....
I added the first channel in the list of my antenna input as a shortcut on my number pad (hold down number 1, for example).
I then added the first channel on the list of my satellite to a second shortcut on the number pad (hold down number 2).
Holding down the relative number was then a quick way to switch between antenna and satellite of "LiveTv", rather than having to go into settings or the filter of the listing guide etc all the time.
    • By Venkata
      Hello Team,
    • By OhmorrowSouthWales
    • By Michael Hirons
    • By leader6234
      Hey guys !!!
      Thanks in advance !!!
    • By Splash
      On power switches selected hdmi
