By
David314
After I installed the recent WebOS firmware update, I ran Netflix and then the app seemed to immediately uninstall from my installed apps on TV (LG E9). I say it is no longer installed, as it does not appear in my installed apps, or app dashboard/bar.
I go to LG content store and attempt to install Netflix app and click "INSTALL", after downloading, a response is displayed "Application has not been installed, try again". I repeat with no success.
Any help here is appreciated. Is this a known problem? I just need to know if a fix is forthcoming?
David
FYI: I note in LG Content Store, Netflix Version is listed as 1.4.86 (Updated: 11/05/2019). While the update date is obviously recent, the version seems very old (only speculating here).
gobby24
Hello.
Yesterday I wanted to watch a show on HBO GO on my LG smart TV and when I opened the app, it said something like "the provider doesn't support this app" (can't remember the exact words) and the app got uninstalled right away.
I searched for the app on LG Content store and it isn't there anymore. Also, I didn't manage to find any news regarding the removal of the app.
Did anyone encounter this issue? Is there a fix for it?
Thanks!
