How to upgrade webOS 2.2.1 to 3 or higher (55UF850T-TB)
23 hours ago, Samson Owoka said:
Please I need guideline/instruction on how to upgrade the webos on my LG TV 55UF850T-TB to WebOS 3 or higher.
Thank you.
If there is an upgrade available on LG's website then you would be able to upgrade using a USB drive.  However if there is no upgrade available then I am afraid you are stuck with v2.
