Just only Netflix, Amazon prime, hotstar, zee5 provided in LG content store this is called as smart TV how?  it dose not content any other applications which are really required, when LG provides this indian apps then only TV get smart.
Hi Hanmant,
As with mobile phone OS creators the said manufacturers do not produce (with obvious exceptions like apps to access their own products) all the apps to run on their platforms, the same is true for Smart TV platforms.  LG do not produce the app, so if your favourite content provider does not produce an app then you need to lobby them to do so.  You can also use the official LG contact form (https://www.lgwebos.com/topic/2550-lg-has-a-feedback-and-suggestions-form/) to let LG know you would like apps for particular content providers.  This however will just be in the hope that LG will make overtures towards the content provider to show them that there is a desire for them to create an app for the webOS platform.
  • Confused 1
My lg 43 inches smart &3d TV with lg web os doesn't have apps like zee5 which is available in other models .I think buying of smart TV is my biggest mistake I have purchased TV three years back.kindly help by providing at least some comment use apps like hotstar,zee 5 ,alt balaji as already demanded by various users.
  • Thanks 1
Surprisingly even those apps supporting latest models is not on slightly old smart TV models (42LB6500-TH). Hope LG ensures support to all their models as done by Amazon, Netflix..
    • By Pranay Mokida
    • By Jaswinder Sandhu
    • By MNHL
    • By Tobin
      Tobin
    • By Luka Pantsulaia
