Netflix resolution
i've try to search in options but i can't find any solution:
is there a way to change resolution of the video otput of Netflix?
my main problem is i've a "consume" connection with limited Gb per month and i want to consume less Gb with some contents
in my android tv box I seem to remember there were option near "language and subtitles" to select video quality or in the general settings of the app...
    • By Nicola123
    • By dolbnya
    • By svsrama
      Sriram.
    • By cptl
      Any thoughts?
    • By Sandtonman
      Dolby Vision is 22.11.
