No channel guide with magic remote.
By Peter_T
By RJ Fischer
By u84six
By joepineapples90
So I'm thinking about buying an oled65g46ls, however the included 'magic' remote would be useless to me, due to health issues (tremors). So my question is, do any other LG remotes work with the G4?.
- 3 replies
- 1,517 views
- 695 views
- 0 replies
- 654 views
- 1 answer
- 3,126 views
Sandip Nath
I have made the settings for Universal controller on the LG magic remote and it can now operate my set-top box, dvd player etc. with one exception. The tv remote can start/stop the settop box, change channels with the up/down arrow keys but there is no channel guide from where I select a channel visually. The channel guide page shows an empty table after the guide button is pressed on the remote. But everything is fine when I operate the STB with its own remote controller. I am using Tata Sky set-top box in India. Please help.
