  • 1
Panel failure
Anyone else suffer panel failure on
LG 43UJ630V 43 inch 4K Ultra HD HDR Smart LED TV (2017 Model)
This set is barely two years old and the screen has 'bloomed' showing large patches of purple/blue at various parts of the screen. LG customer service didn't want to know about taking it in for repair let alone a refund. Worst quality ever and utter disgrace the cheap components fail just outside the pathetic two year guarantee. The OS restart error seems to have finally been fixed now but as the build quality and picture quality - even when new - is terrible I would advise against buying from this company in future.
Mine too!
I have 43UJ634V ultra-HD 43". The same thing started happening. My warranty of 2 years just finished over a month ago. Purple/blue patches in two large spots.
I love LG cause they offer the advanced tech but cheaper than other companies, so I should expect them to be of worst quality but not soooo much worse.
They are engineering their products to fail after guarantee is over. I had an older LG FullHD which was better build quality and that started breaking after 4-5 years (had a relay clicking sound while turning on and took forever to turn on but I fixed that) and now this.
I am starting to be really dissapointed with LG's products. They need to fix the buiild quality in general.
Did you find any solutions to your problem? Is it fixable?
    • By Darshan Giri
      I was unable to install the remote control app(on TV) after bundling with Sandstorm webdriver code. Getting below error. ares-install ERR! [com.webos.appInstallService failure]: luna-send command failed <update manifest file failed>
    • By Glen
      Appears that my main audio amp has failed, no audio from TV speakers.
      The pre-amp is okay since I plugged in sound bars, wireless headsets, and optical connection all ok.
      The repair would cost around $300 so I decided it was cheaper to buy a soundbar.
      Anyone else experience this problem, ie no sound from the TV speaker?
    • By philotas
      I followed these steps to prepare my LG TV and it all worked fine:
      However I cannot push IPK to tv or just list stuff:
      I am getting this error when calling:
      ares-device-info --device tv2 outputs:
      ares-device-info ERR! [syscall failure]: read ENOTCONN Any ideas?
      I can ping the TV just fine and getting the key from the TV also worked but connection fail...
      I am using macOS 12.16 and the TV is using webOS 4.9...
      I also tried different node versions (v8.17.0 and v17.3.0)
      Any ideas?
      Boasting the Fastest OLED Performance of Any UltraGear Models,
      Company’s New 27-inch and 45-inch Monitors Deliver Next-level Gaming Immersion
      SEOUL, Dec. 12, 2022 — LG Electronics (LG) is exhibiting its latest lineup of premium UltraGear OLED gaming monitors (models 27GR95QE and 45GR95QE) at CES 2023. The new UltraGear monitors demonstrate LG’s leadership in the fast-growing OLED category and its continuing strength in the global gaming display market.
      Equipped with the world’s first 240Hz OLED panel,* which is exclusively manufactured by LG, the new 27- and 45-inch models deliver a record-breaking response time of less than 0.03 milliseconds Gray-to-Gray (GTG), not to mention superior self-lit picture quality complete with accurate, lifelike colors and infinite contrast. Courtesy of these cutting-edge display technologies, the latest models tick every box when it comes to what consumers want in a gaming monitor.
      27-inch OLED Gaming Monitor with Unprecedented Speed
      LG UltraGear OLED Gaming Monitor (model 27GR95QE) offers the level of performance needed to get the most of the latest game titles; its QHD (2,560 x 1,440) resolution OLED display providing a 240Hz refresh rate and a staggering 0.03ms (GTG) response time for delightfully smooth, low-latency gaming. It also covers 98.5 percent of the DCI-P3 color gamut, ensuring vibrant graphics that fully capture the vision of the game designers and digital artists who created them. Additionally, the monitor’s Anti-glare & Low Reflection (AGLR) panel makes it easier to see what is on screen so that users can enjoy a distraction-free gaming experience regardless of ambient light conditions.
      Featuring support for variable refresh rate (VRR), NVIDIA G-SYNC Compatible, FreeSync Premium and VESA Adaptive Sync, LG’s 27-inch UltraGear provides seamless visuals with minimal tearing or stuttering. It also supports HDMI 2.1 specifications and DisplayPort 1.4 connectivity, and incorporates a 4-pole headphone jack that allows users to relish the realistic, spatial sound of DTS Headphone:X. Meanwhile, the included remote control provides quick and easy display management plus the added convenience of programmable hotkeys.
      Next-level Immersion with 45-inch Curved OLED Display
      A CES 2023 Innovation Award honoree, model 45GR95QE is LG’s first-ever 45-inch curved OLED gaming monitor with a 21:9 aspect ratio, WQHD (3,440 x 1,440) resolution screen. It is also the very first 45-inch display with an 800R curvature: an exciting, new form factor designed to deliver next-level gaming experiences. Certified as a low blue light product by leading global testing organizations TÜV Rheinland and UL Solutions, the matt Anti-glare & Low Reflection OLED panel of the curved UltraGear monitor is easier on the eyes than a conventional LED panel, meaning users can play for longer with less eye discomfort.
      The 45GR95QE’s remarkable, curved OLED panel offers a 1,500,000:1 contrast ratio and 98.5 percent coverage of DCI-P3, producing the bright colors, deep blacks and crisp images that not only make the onscreen action come alive, but also heighten the player’s focus. Like its 27-inch sibling, the 45-inch model has a response time of less than 0.03ms GTG and a 240Hz refresh rate. Harnessing the immense potential of OLED, the 45GR95QE provides total gaming immersion.
      “Featuring our industry leading display technologies, these purpose-built monitors boast the speed needed for competitive gaming as well as picture quality that makes everything look and feel more real,” said Seo Young-jae, senior vice president and head of the IT business unit of LG Electronics Business Solutions Company. “As a pioneer of the gaming space, LG will continue to invent completely new customer experiences through its high-performance LG UltraGear gaming monitors that come in various sizes and form factors to satisfy every kind of gamer.”
      Visitors to CES 2023 from January 5-8 are encouraged to stop by booth #15501 in the Las Vegas Convention Center to experience the latest UltraGear OLED gaming monitors. Available to pre-order in the U.S. starting December 12, LG’s latest OLED gaming monitors will be launching in key markets throughout North America and Asia in January, in Europe from February, and in the Middle East and Latin America in the following months.
      Specifications:
      LG UltraGear OLED Gaming Monitor (27GR95QE)
      LG UltraGear Curved OLED Gaming Monitor (45GR95QE)
      Display Type OLED (AGLR) OLED (AGLR) Screen Size 27-inch 45-inch Resolution QHD (2,560 x 1,440) WQHD (3,440 x 1,440) Color Gamut DCI-P3 98.5% DCI-P3 98.5% Contrast Ratio 1,500,000:1 1,500,000:1 Refresh Rate 240Hz 240Hz Response Time 0.03ms GTG 0.03ms GTG Curvature – 800R HDR HDR10 HDR10 Connectivity HDMI 2.1 x 2 DisplayPort 1.4 x 1
      USB 3.0 x 1 Upstream
      x 2 Downstream
      4pole H/P out (DTS HP:X)
      x 2 Downstream
      Speaker N/A N/A Remote Controller Yes Yes Stand Tilt: -5º to +15º Height: 110mm
      Swivel: ±10º
      Pivot: 90º (Counterclockwise)
      Swivel: ±10º
      Pivot: Not Available
      * As of December 12, 2022, there are no other OLED monitors available on the market with a 240Hz refresh rate.
    • By Sreejith
      My original TFT panel was blacked out and it was out off warranty, the replacement panel also blacked out in just 2 months while I was watching and it also generated a crack by its own. What are the reasons for a panel to crack by its own. Can I avail warranty for the same, my replacement panel is under warranty.
      49UK6360PTE.ATR
