lg smarttv remote Re-connect Netflix button?
By JonoW
By Nicola123
By Marko00
only with cancel button.
How to fix it?
By toopie28
Hi can someone help please.
Not sure what else to try.
Thanks!
- 836 views
- 2,082 views
- 2 answers
- 5,982 views
- 4 answers
- 3,298 views
Nashbarry
After switching to a new modem, the "Netflix" button on the LGSmartTV remote will not connect to the app. (I cana get to Netflix via the cable box app, on same TV, or even Apple TV, but not the easy LG remote button. NO FAQ suggestions seem to fix it. What to do?
Link to comment
Share on other sites
3 answers to this question
