Pin code for tv
By 43UR81006LJ
By Ramya Shyam
By R M
Dear All
can anyone share area code of India region for LG OLED C3 currently on webOS 8 - 2023 model
want to activate India region, currently in UAE.
By chupo_cro
I have LB650V webOS TV and it is very annoying having to reselect the (Latin 2) subtitle encoding (Code Page) every time when playing the movie. Absolutely no excuse not to save the last used choice for the subtitle Code Page so I hope it will be implemented in the future firmware updates.
And one more thing about the subtitles: the options to turn on the transparent background and/or the character outlines has to be done - to improve the readability.
James dorman
The pin code isent working on tv
