TV connection to WiFi not working anymore
LG WebOS TV UK6090PUA
not connecting to WiFi. WiFi has been rebooted several times; TV has been unplugged several times. Neither of these seem to help. WiFi is definitely working in the home. Please advise.
3 answers to this question
  • 1
There have been several threads about this over the past few months.  The solutions ended up only being temporary fixes for me, I ended up purchasing a ROKU and it’s working well, and depending on how old your TV is, ROKU has access to more apps and channels.
Contact with LG customer service. Probably Wifi module issue. Sometimes Wifi module + mainboard together. I had same problem, 1 time wifi module changed, 2nd time wifi module + main board changed. 3rd time they tired use special sticker on flex cables. After 2 months they changed my tv with new 2019 sm8200 model tv.
    • By crct
    • By NickL
      Br,
      Nick
    • By agus
    • By Rex G
