Cannot play mp3 from phone to smart TV
I am trying to stream and display my favorite song collections on a smart TV, all failed. I had previously used samsung s3 to connect via bluetooth, but when i used iphone x to connect, the system reported an incompatible error. Can someone tell me why the connection was not successful? Here are the songs I want to play on my TV:
Thanks in advance :)
4 answers to this question
It is possible that your smart TV model is too old, so it is not compatible with your phone. Try the play function via the Youtube app. What about
I like to use my favorite songs as my
If it is the matter of iPhone, you can try to have a software update on your iPhone. Or you can fix the iOS system by the
, which can resolve 50+ iOS issues. While if it is the matter of TV, then you can ask related professionals for help.
Posted (edited)
@Bogan Silver FYI: be VERY careful clicking links on this (or ANY) forum, if you do not know exactly where they go, or if you do NOT have a good anti-virus and anti-malware program running. Some of the things I see here look VERY suspicious. DO NOT take any chances, as the other posts on here DO NOT appear to be giving you any considered/logical advice or answers, so DO NOT click the links.
Bluetooth has various connection standards/protocols, and it is a bit of a minefield for old/new device compatibility, and pairing methods, and security layers.  It may be a bit clunky and inconvenient, but you may be better off by preparing a USB stick with your songs/videos, off a laptop or PC, then plugging into your TV. The Smartshare APP and built-in player should be able to play them.
Other solutions involve DLNA servers (e.g. NAS disks, with PLEX or similar on your home network), and using LG Smartshare or PLEX TV to get them played on your TV.
Edited by td47
clarifications
    • By Will M
    • By Joe C
      Since the Web OS update last week, the line on the Home Screen with all my apps has changed.  Now Apps is the first one in the line.  I do not want it there, but cannot move it.  If I go to the end where it shows Edit Apps, I can click on any app to move it or delete it.  But, the Apps icon is grayed out and cannot be moved.  My neighbor has the exact same model I do -- LG OLED 653PUA -- and it is not like that on his tv.  He can move the App icon anywhere he wants.  This is very annoying as it defaults to the Apps icon when I click on Home and then I need to click to get to YouTube TV, which until the update was always first in the line.
    • By Lesbo
    • By Rex G
