alexa
By Trevin
By Citron2010
Hi, I have an LG 43UN71006LB with OS v4.50.53 (latest)
I thought I'd test this on my TV and it works very well. I've even set "routines" on Alexa so that saying "Alexa, BBC 1" is a shortcut for "Alex, change the channel on LGTV to 101" etc.
Also tried:
"Alexa, enable Sound Share on LGTV" - "that command doesn't work on device LGTV"
Anyone have any ideas?
By Sandy8100
Alexa installed correctly on 32lq63 TV.
remote that came with to does not appear to have a microphone. How do I control Alexa?
Simple instructions for a simple person please !
By NThakare
Until last few months, alexa was working with all the commands, now open any app like Youtube, Netflix, etc not working
Play or Pause any app videos not working, don't know what's going on with lgtv, i bought around 1000 dollar tv and this important feature isn't working
By NThakare
Hi all,
If u all can check, alexa on my lg c2 oled 55 inch has stopped working sometimes it gives error like its unable to connect to server and now when i give commands to play or pause any music or video, it says it can not do it.
I have reset it multiple times it does not work.
Many users on alexa app skills for lg tv webos are also talking about the same, that means its not limited to me only
- 1,552 views
- 1 reply
- 4,815 views
- 1,681 views
- 4,007 views
Steven Fisher
Alexa we'll turn the TV off that won't turn it on
