Memory error
By Batman
Serial Number:- 309MAUAGGP74
Programme Mode:- Antenna
Software Version:- 23.21.30
By andystaffs
Just bought a new LG 43UT91006LA TV .
After one week we're getting a "short of memory " screen warning before TV shuts off and restarts . I've not loaded any apps but I've managed now to delete one . I've checked that the apps are updated . I'm thinking that I can rid myself if the games but not sure how to do this ..I'm a bit baffled that a one week old TV can't cope with it's pre- installed apps ?!
By Marko00
only with cancel button.
How to fix it?
By leader6234
Hey guys !!!
Thanks in advance !!!
By Muser
