Youtube TV launched upon turning TV on?
By Lee Magee
By Will M
By David Joseph
By Владимир Морозов
By JonoW
DLN511
I recently switched my parents over to Youtube TV and they have a 50" 4K LG TV (don't know model number, it was bought in 2018). Is there any way to have the TV launch into the app instead of one of the connections? I've looked in the source input screens but can't find anything for it. Otherwise they have to bring up the app screen everytime they turn the TV on to select Youtube TV
