Error loading media. File cannot be played
I've been tackling this for a while. I'm trying to play an internet TV, but some of the channels drop me an error. Happens with couple of online movie sites too. Contacted my ISP, but they couldn't help.
Can this be related to webOS? I've checked, and the firmware is brand new. The LG model is TV UJ7507.
Any help is appreciated.
    • By Joe C
      Since the Web OS update last week, the line on the Home Screen with all my apps has changed.  Now Apps is the first one in the line.  I do not want it there, but cannot move it.  If I go to the end where it shows Edit Apps, I can click on any app to move it or delete it.  But, the Apps icon is grayed out and cannot be moved.  My neighbor has the exact same model I do -- LG OLED 653PUA -- and it is not like that on his tv.  He can move the App icon anywhere he wants.  This is very annoying as it defaults to the Apps icon when I click on Home and then I need to click to get to YouTube TV, which until the update was always first in the line.
    • By Lorenz
    • By wallyricks
    • By Marko00
      only with cancel button.
      How to fix it?
    • By leader6234
      Hey guys !!!
      Thanks in advance !!!
