Apps and browser not working correctly since update
By OliverRC
By Ajothen
By Roy Brown
By Batman
By mean2
Guinevere
LG Smart TV - my auto-updates is on, and the firmware is on latest update (04.05.85). Since this update in June 2019 I can't access my Showmax app and the web-browser says that it needs to update. The browser gives the option to update Chrome, but LG TV doesn't support this update.
How can I manually update apps and the browser? What else can I try?
