turning off hard of hearing
    • By Flavio_S
    • By tezz7624
      tv keeps turning on of its own accord mostly in the small hours of the morning
    • By Laurence
      I have an LG65UR80006LJ and when I plug my portable hard drive in to one of the USB ports, it lights up and sometimes the thumbnail folder gets added by the TV (I can see it when I plug the drive back into my PC) and twice now it has operated as expected and it appears as a device on the media app.
      But it has only worked correctly twice and now doesn't find the drive at all, despite me having reformatted it and only add one file to the root directory (the first page if this makes sense; not buried in sub folders.)
      Before I box the TV back up and send it back, is there anything else I need/can do as my 12 year old Philips smart tv has no problems what so ever finding the drive and playing the media on it?
      Thanks in advance for your help.
      Laurence
    • By williamsats
      Hi everyone!!!
      Lately I have a problem with my 40UH630V (OS Ver. 05.70.30). It takes too long for a hard drive or a USB stick to get it ready to play video files. That means that I have to plug in my hard drive or USB stick and wait for at least 4-5 minutes before I can play the video files, no matter what type/format they are. Sometimes I have to unplug and re-plug my drive so to read it.
      Here I must point that both USB ports are clean with no dust or any corrosion, USB cables are new and fully functional and all hard drives and USB sticks are working perfectly on my 32LQ63806LC.
      Also in some cases i get a message on TV for a format compatibility but I don't think this is the case, since if I wait 4-5 minutes (sometimes a bit more) then it reads them normally.
      Any ideas?
    • By Extra Celestial
      Would love to auto start the Alexa app so my smart home can connect to it automatically when I turn it on from a plug since you can't turn on the tv with the hubs.
      One small workaround instead of trying to figure out how to turn on the tv from a hub since it disconnects from the wifi when it powers off.
