Programme Guide slow
The programme guide takes far to long to populate. Also when in Programme Guide and you go to next page the same happens.
Toshiba, Panasonic and Samsung TVs don't have this issue. Presumably they download  the Programme Guide in the background and store it in the TV's memory.
Or is there a fault with my LG?
Mine is also very slow. I have a 5 year old smart TV. It also has missing programme information regularly in the last year and the recording doesn't always show the title. Instead the title is No Programme Infomation.
    • By Mandx
    • By Peter_T
    • By pivotCE
      3. Soldering iron and solder
      2. Items 2-4 above
      1.
      2.
      Prepare the Wires
      Final Thoughts
      #webos4ever
    • By pivotCE
      Tools for the Job
      – Needle nose pliers/tweezers
      – Flush cuts
      – Painter’s and kapton tape
      Trim the USB C Board
      Tape the USB C Board
      Where To Get Power and Data
      Put the Pieces Together
      Congrats, You Now Have USB C
      #webOS4ever
    • By RussS
      Russell
