By
atcronin
PHS
Hi, I'm experiencing some strange changes in how my AppleTV 4K behave after updating the LG [WEBOS] to 05.10.35.
I own an OLED65C8PLA
LG SoundBar SL10YG
When I start an App, it takes much longer time to get it up and to run. When I close the app, the screen turns black and can blink ones or twice and then finally I see the ”Home screen.” Sometimes the screen stays black and I need to restart the AppleTV 4K Device. This behaviour has never occurred before.
PS. I have restarted all devices that are connected to the TV.
I will write updates later if I detect anything new or if I find a solution to the problem.
