Bluetooth & Google Assistant Connection problems
By JamesH
By Fredrik Andersson
By ato53
I have a new C4 TV.
Thanks for the follow-up
By Kane Murphy
By akhil7j
Ian Wale
Unable to make Bluetooth connection between TV and mobile phone. Phone shows LG Tv but will not pair with it? TV is OLED55B9PLA.
Unable to connect with Google assistant to access my Google diary, message indicates that device not connected but I am unable to resolve issue. Weather info works fine?
5 answers to this question
