Can you not Airplay 2 to a supported LG TV when the TV is turned off?
By Evelynn
I am trying to access Livenettv through my LG smart TV however I keep getting the downloading not supported when wanting to download V4.7 apk file. Please can you advise?
By matesz
PS2. I've heard that Denon AVR-X3600H works but this is massive overkill for what i need (i don't indend to go beyond stereo, not even 2+1).
By dolbnya
By odesanmi kolade
I have been trying to downloading Aptoide TV on my LG smart Tv but keep showing File downloading not supported.. My goal is how I can get zoom conference app running on my Smart Tv. Please help!!!
By williemyers
hi all,
for a couple of years now, I've enjoyed AirPlay between my mid-2012 MacBook Pro and my LG Smart TV. But last week, I had to do a Migriation Asst./Time Machine re-install of the system drive on my MacBook Pro/Mojave. Result is that I can no longer get a connection with my LG TV. Two things:
When attempting to AirPlay connect, I now get a Mac window asking for a PIN code. Then , the LG goes black and gives me a 4-digit AirPlay code, I enter it in to the Mac, but it reports, "could not connect to LG TV" etc. 2. I've put an AirPlay icon in the menu bar, but when I click on it, I see a greyed-out "AirPlay:" that constantly switches back and forth between "AirPlay: Looking for TV..." and "AirPlay: Off"
All help/thoughts appreciated!
- 10 answers
- 1,993 views
- 5,598 views
- 4,601 views
- 1 reply
- 4,476 views
Paesano
Can you not Airplay 2 to a supported LG TV when the TV is turned off? HomeKit works when the TV is on or off and Airplay works only when the TV is on.
My TV is a C9 series.
Thanks!
