Slow Programme Guide
By Mandx
By Peter_T
By pivotCE
3. Soldering iron and solder
2. Items 2-4 above
1.
2.
Prepare the Wires
Final Thoughts
#webos4ever
By pivotCE
Tools for the Job
– Needle nose pliers/tweezers
– Flush cuts
– Painter’s and kapton tape
Trim the USB C Board
Tape the USB C Board
Where To Get Power and Data
Put the Pieces Together
Congrats, You Now Have USB C
#webOS4ever
By RussS
Similar to what TIVO offers in there guide I would like to see "First Aired" date. That way I know if something is a repeat or not.
Russell
- 0 replies
- 1,087 views
- 1 answer
- 10,110 views
- 0 replies
- 4,580 views
Questions about LG Web OS Smart TV and Dish TV Set Top Box
By AnonViewer,
- stb
- mychannels
- (and 2 more)
- 14 answers
- 11,923 views
Den C
24 answers to this question
