LG c9 YouTube TV & Google Assistant
Recently bought a 55" C9 TV and with Google Assistant setup when I ask it to launch YouTube TV it always pulls up Youtube instead of Youtube TV.   Has anyone experienced this or could I be doing something wrong?
    • By Lee Magee
    • By Will M
    • By David Joseph
    • By Владимир Морозов
    • By JonoW
