Hi All,
Has anyone had a recent update of the OS on their TV to 4.7.050204 (goldilocks2-gulaga) ?
The reason I ask is that the IPTV channels on my TV seem to have borked these channels as I now get "Invalid Service"
floating across the screen. I'm pretty sure these channels worked before the update.
I'm referring to channels such as Now 90's, Planect Knowledge, The Sports Channel Network etc. So these are NOT APPS but
TV Channels showing up on the guide and still show the programme details.
This TV is only a week old, and I think I'm going to be bounced between the retailer and LG as it seems to be a software issue.
Does anyone have similar experiences and have you resolved the issue ?
TIA
51.sqn
Hi yes i have the same issue and i am not happy. LG said it this the broadcaster who is at fault  which is ridiculous. I have reported this to BBC Watchdog I hope you do the same as there does not seam to be a solution
Quote
I have a similar problem but for the UK Freesat channels. BBC, C4, C5 etc load into the channel guide EPG but when I select any station it displays a blank screen with "Invalid Service" error.
Initially setup with region Ireland so thought that might be the issue, but I have just reset to factory settings and tried UK, with same result on selecting Satellite - Freesat.
I'm connected directly into the DVB-S2 tuner of the TV from an old Sky dish.
Considering purchasing a setup top box but really why should I have to spend more money on an additional device when the LG set should work as advertised?
    • By mean2
    • By OliverRC
    • By Ajothen
    • By Batman
