wifi won't connect
7 answers to this question
1 hour ago, Bingo said:
Yup its happening, turn of tv disconnect power, turn off wifi router, then powwr both on it will work now.
Thanks. tried it but it still shows WiFi is turned off
In the manual it is explained how to turn wifi on on the sb.
I don't have a manual available to me as the TV is mounted in our class A motorhome and wasn't provided a manual to look at. Ive looked online but there is no reference to this.
    • By agus
    • By JamesH
    • By DavidSr
    • By Fredrik Andersson
    • By akhil7j
