How can I turn off Listening mode in WebOS 04.70.05
To all,
I hope someone can help me. We recently bought an oled55e9 en we are actually quite pleased, apart from the wifi being to slow and sometime dropping.
After doing some research I found many could resolve this by disbaling the 'Listening Mode' in settings for Screen Sharing....
My problems now:
  • In the menu, under screen sharing, I can only delete existing connections, which we don't have
  • In the smart menu I don't have an app screen sharing
  • I cannot find the app in the content store so I cannot install it
How do I disabled the Listening Mode in WebOS 04.70.05 so I can hopefully start streaming without lags and hick-ups
Thanks in advance,
Raymond
    • By Justin Bester
    • By atcronin
