WiFi Connected but unable to download anything.
I have just taken delivery of a Lg 55UM7100PLB television and have gone through all the rigmarole of being unable to download the agreements. I finally did it by the method described on here by using a hot spot on my mobile phone. I now find that I cannot access anything on the internet at all and just get error 105. I have switched from wireless to Ethernet and it's still the same. I have other devices (Sky box, kodi Box etc) connected to the same router and they have no problem at all. I have tried changing the DNS to 8.8.8.8 and 8.8.4.4 but to no avail. The TV shows that it's connected to the internet but refuses to do anything at all when connected via the router. Has anyone had a similar problem? My router is an ASUS RT-AC68U and has been modded by installing Asuswrt- Merlin because my ISP operates a transparent DNS and my Sky Box etc do not work without the modified router. Any advice will be gratefully received.
    • By agus
    • By Hasan Ghasabi-Oskoei
      Can you help?
    • By keshav iyer
    • By Kane Murphy
    • By Tunari
