- 1
Cannot find an app on LGContentStore
By Joe C
By starwoodtech
By Peter Steinmeijer
Is my TV too old ?
By JayDee
I have spent countless hours trying to figure out which remote is compatible with my 27 inch LG television. I can find the TV on LG's website (after intensively searching each time), but when I search the Magic Remotes for compatibility, I've had no luck in anything matching the two.
TV model is 27LQ625S-PU, purchased from Best Buy in America. I'm running 7.3.1-38 for webOS TV version. Trying to purchase one elsewhere online also seems to not have anything resembling my TV make/model.
I don't know what else to do in order to find a remote that works, and I don't want to spend the money trying ten remotes until finding one that does. Am I missing something through the site where I should be searching? Do all remotes work based on webOS version? I'd really love to upgrade this mostly useless remote. I don't use it much right now because I don't like typing through the on-screen keyboard and the remote that came with the TV isn't as easy to use as a universal (I think some of the buttons are in oddly located places). I tend to use external smart devices because the (dumb) remote/webOS don't seem to pair together very well.
I appreciate any help you guys are able to offer, and apologize if this seems like a foolish question.
By Stephen Davies
Jzurge
Please help as I cannot find an specific app on LG Content Store. I have 2 LG WebOS TV, 1 unit of 2016 Model and the older is 2017 Model. Both TV have the same configuration like (broadcast country UAE,), connected on the same wifi network. I was able to find the app on the 2016 Model but not on the 2017 Model.
Is there any other way to install the app aside from the LG Content Store?
