  • 1
Video Player Needed
I am looking for an app that will allow me to play videos from a shared folder on another computer, something like VLC. Is there an app for the LG to do this? I haven't been able to find anything. I set up the Media Center on the other computer but it doesn't work right and can't see all the available videos. I just want to be able to browse a shared folder.
Chuck
17 answers to this question
Hi chuck
I use Plex to stream my movies etc to my TV. That might be a good way for you to go, you just need to install the plex server on your computer and sign up. Most LG TV's also support DLNA nowadays anyway so you could always use that. It could also be that not all the files you're trying to watch are a supported format etc?
Ash
I have tried Plex before and it didn't work well. I don't remember why. I think it had something to do with the way the file names were listed. I was trying to check out WebOS but I can't find it or figure out how to install it. The Media Center in Windows has known problems that I ran into, such as not creating a complete list of videos.
I looked up DLNA and found a list of software that uses it. In the list was PlayOn, which I already have on my computer! I turned on the Media Library and it works great, allowing me to browse the folders where my media is stored. Thanks for getting me moving on this!
Chuck
I have the same problem
@Csaba Bakó Did you follow what @CpRivers found to work? That is, media centre and PlayOn?
If you computer is a Windows 10 system, I recommend you ensure to get it updated to the latest Feature Update called 20H2, as many user have found this works very well "projecting" the screen to many TV models, including many of the newer, and certain older LG models. That way you can use any of the Video Players, such as VLC, WMP (Windows media Player), YouTube, Cyberlink etc, and "mirror" the PC screen.
You can also try using the in-built File Explorer, go to your Video Library,  right-click on a video file, and try the "cast-to" option. If your TV is on the same network as the PC and recognised, you should be able to play it over the network. NOTE: you will need too ensure that "Media Streaming" is turned on in the Windows 10 settings app or Control Panel.  Theasiest way to find that, is to click on the notifications bubble icon at the bottom right, choose "all settings", then in the search box type in the word media, then you will be able to select the Media Streaming settings shown in the select list.  Turn that function ON, ensure ALL your media devices (DLNA servers,  and the TV) on the network are turned on, and ensure you have ticked the "allow" for them to be used.
The DIVX video player ALSO has its own media server that i have played with for streaming to a TV, but it is a bit clunky, AND the DIVX Server stays active in the background when finished playing your videos, and will stop the PC from staying in SLEEP mode, unless you right-click on it and exit it after use.
Want a VLC alternative? Share you with the totally free JoyoPlayer from
. It can play all videos, even  including 3D, 4K, UHD videos and audios on Windows and Mac. It comes with multiple play modes and preferences settings.
Here is my question is i want to play videos from the external devices like pen drives. Some movies are not supported in lg tv web os.
Kindly suggest some video players like vlc, MX player that supports on lg tv web os
I do as well.  I don't want to run W10 servers or Linux or do this anywhere but play on the LG TV from the LG TV.  I have  12 TB of NAS storage in folders by media type and by month, year, decade, and century.  (about 125,000 pictures scanned and digital) and about 1/2 the content is video movies and some instructional stuff.  I want to access the NAS folders (PLEX or the version I have does not seem to do this intuitively or its too cryptic for me to figure out)
As another mentioned VLC would seem to work but we need a WebOS version and I don't see or can find one.  One shodl be able to just Open a file on the NAS box and load it and play.....just like VLC does on W10 and even Android.  etc.
Three items.  1) Content on NAS file system, 2) LG TV on the network with WebOS, 3) the missing link or software video player?
more searching and I am diving into this quagmire of information and stuff.....  https://www.webosnation.com/best-webos-movie-and-video-apps
This seems to be a windows or server based product also.   I guess a File Manager on WebOS on the LG tv would be a first start to find the video and then launch it?   I used the Web Browser to get to my https://primarysixterabyte/  NAS storage server on my network and that seemed to work.
Then I launched the videos and really not sure WHO ended up displaying/playing them.....but it worked.  Pretty clunky going up and down folders and hierarchy with the clicking of "keyboard" and finger pointing the cursor......but its working?
Still looking for a LG APP Player like VLC for WebOS or maybe MediaMonkey for WebOS.........
It is ridiculous that in 2022 the webOs can't play mp4 videos cause it's missing decoding libraries... I can't understand how you guys are thinking to give a smart service without a media player... I'd never ever suggest an LG TV to anyone.... I'm still asking myself why I didn't buy an android TV.
Is there a video player for WebOs that could play mpeg and stuff? There're no VLC, MX player, Joyo player at the LG content store. It seems rather strange that in 2022 there're still problems with playing mp4 files on the WebOs.
Yes, it's unreal
    • By wallyricks
    • By murastefano
      How to show video cover art on  SmartShare on WebOS ?
      I have many movies, mp4 or mkv file with cover art muxed,  but SmartShare
    • By MNHL
      In its mission to share the message of Life’s Good, LG
      link hidden, please login to view earlier this year to infuse more positivity into the social media experience.
      To further ignite optimism worldwide, LG Vietnam officially titled “An Optimism Universe.” The video features Phương Mỹ Chi, a famous Vietnamese singer and an ambassador for LG Vietnam’s local campaign.
      The song is a reimagined version of “A Universe with You (Vu Tru Co Anh),” Phương Mỹ Chi’s hit track which captivated the country’s youth on social media. Now, as the sound of LG Vietnam’s latest campaign, “Power of Z – Spread out the Optimism,” HIT music producer DTAP has remixed the melody with trendy and upbeat elements while retaining the original’s distinctive Vietnamese traditional folk elements. With relatable and meaningful lyrics, the song encourages Vietnamese youth to live in the moment and enjoy every aspect of their lives.
      The music video takes viewers on a journey across iconic landmarks of major Vietnamese cities, inspiring the younger generation to explore everything the country has to offer. Vibrant red hues and dynamic motion graphics jump across the screen for a visually stimulating experience that encourages viewers to join hands in creating a better future from the simple joys of life. In the video, LG Vietnam’s Gen Z ambassador also extends an invitation to tour , a unique space where visitors can experience LG’s most innovative technology through exciting activities.
      “An Optimism Universe” delighted listeners from the moment of release, reaching an impressive 1 million views on YouTube within just 24 hours. The momentum continued, culminating in a total of 18 million views across all platforms in a mere 10 days.
      This theme song debuted at the Uni-tour of Saigon University in Ho Chi Minh City and the National Economics University in Hanoi, where approximately 3,000 students were met with a fun-filled playground of colorful experience zones organized by LG Vietnam.
      The first space, the Optimism Melody zone, presented students with the opportunity to express themselves through karaoke, enhanced by hands-on experiences with the LG StanbyME and StanbyME GO.
      Nearby, the Optimistic Hints of Tarots zone invited students to discover a unique, positive message revealed with a touch on the LG StanbyME screen.
      Students could share their event experience at the Capture Optimistic Moments zone to receive an optimistic framed photo, while the exhibition space at the Wall of Optimism zone showcased the students’ creative ideas to spread optimism to their friends, relatives and the community.
      In an effort to expand the reach of the Life’s Good brand mission, LG Vietnam also aimed to make a tangible difference in the community with practical support. Enriching cultural life and improving education in rural areas, the company joined hands with the Green Summer 2024 Campaign, an annual event organized by the Vietnam Student Association. Launched in 1997, the campaign provides students with leadership opportunities in social initiatives, including building roads, bridges and charity houses, as well as participating in educational programs to eliminate illiteracy and improve digital competency.
      LG Vietnam donated 27 LG TVs to the Green Summer campaign this year, nine of which were specifically designated for a community housing project in Dak Nong province. The remaining 18 LG TVs were given to remote schools to provide better teaching and learning conditions for both teachers and students.
      Vietnam’s “Power of Z – Spread out the Optimism” campaign reaffirms LG’s commitment to connecting with the younger generation and encouraging young people to approach life with an optimistic attitude, create a positive impact on the community and contribute to a better future for all.
      To spread the message to a wider audience, people can also share positive moments from their daily lives as part of LG Vietnam’s social media challenge with the hashtags #LifesGood, #TíchCựcLanToả and #NụCườiLanXa.
      Additionally, LG employees participated in a for the campaign, contributing to a greener learning environment for students.
      LG actively promotes activities and initiatives that create a better life for Vietnamese people through the power of Life’s Good. Through this local campaign, LG Vietnam hopes to spread more joy and happiness, inspiring a brighter future for all.
      Contributed by LG Vietnam
    • By RedNe
      I would like to ask friends in the group, especially someone who uses webos 3.X, to give me Disney+ and Amazon Prime Video *.ipk. many thanks in advance for your help.
