Cannot set up my google assistant on LG 7400plb TB
By Andreas Boyatzoglou
Model: OLED55BX3LB
Viewing videos from
link hidden, please login to view was fine up to about one month ago. I do not know if there was an upgrade, but videos from that site cannot be played any longer on this tv. From the same wifi network (home network) videos from that site play fine to a number of devices (Android phones, 2 win11 laptops, 1 win10 laptop).
By Justin Bester
By Joe C
By Cody LUEN
Hi!
Version: 23.20.36
By starwoodtech
- 1 reply
- 3,750 views
- 3 replies
- 19,173 views
Using the magic remote with Google assistant to operate wi-fi socket outlet
By fade2gray,
- magic remote
- google home
- (and 1 more)
- 2,004 views
- 4,047 views
Paul Gleadall
I cannot set up my google assistant on LG 7400plb smart tv
Edited by AlexAdded full topic title with issue from post content.
