Multi-view issues/alternatives/suggestions/help
Hi, I have seen pictures around the web of people having black bars when using the multi-view app. Maybe they are using another tv. I have a B7 and the bars are grey. spacer.png
Every issue I have with the app:
- The top and bottom bars are grey
- You have to turn off hdmi-cec
- Every input shows as 16:9, with black bars if the signal is not 16:9
There doesn't seem to be any 3rd party app alternative available, also I looked into if I could make a webos app but from the few minutes I looked into it, it seems you can not access hdmi inputs from a 3rd party app.
As a last resort, is it possible to downgrade the webos version to one that has the app with black bars?
Playing co-op games in splitscreen from two PCs, each in 8:9 aspect ratio would be cool..
    • By DW1
    • By Željko2
      I own a TV LG oled65c31la.aeu. I am interested in whether it is planned in the next firmware updates to return to multiview the
      option of displaying two live channels (antenna dvt2), as it was earlier in webos 2.
      Previously, a buffer was created in which terrestrial channels were saved, from where they were marked for display.
    • By Željko2
      Hello everyone.
      Thank you.
    • By Ash0837
      Any way to chang picture settings in multiview? I'm able to connect 2 hdmi devices but I'm unable to change picture settings while in multiview. It's locked on Vivid mode. Any way to change to game mode? Both hdmi inputs are on game mode, but multiview is on vivid.
    • By Brendanchatt
      Hello all,
      From what I can tell, this may not be supported anymore.  I am on webOS TV Version 7.1.0-68 (mullet-maria).
      I just purchased an OLED 42 inch C2.  When I select Multiview, the two hdmi ports are not an available combination.
      I have turned of CEC (now SIMPLINK) for both HDMI inputs as I read in a post from 2018.
      Thank you,
      Brendan
