Oliche Posted January 15, 2020 Posted January 15, 2020 Hi everyone i ´d like to connect a WD hdd of 4 Tb to watch my pictures on my C9. But before to buy the hdd, I ´d like to know if the tv will recognise it? thank you in advance Quote
0 Karan Batra Posted January 22, 2020 Posted January 22, 2020 On 1/15/2020 at 8:50 AM, Oliche said: Hi everyone i ´d like to connect a WD hdd of 4 Tb to watch my pictures on my C9. But before to buy the hdd, I ´d like to know if the tv will recognise it? thank you in advance I have a 2tb Portable hdd that works perfectly. I also have a 10tb which also works fine but its powered. So 4tb should work fine 99% . The TV can support the 4tb hard disk, its just that it might not be able to supply sufficient power if the 4tb requires more power than the 2tb. In the unlikely case it doesn’t work you’ll need a powered USB hub to connect the hard disk. It will then work for sure. Quote
Oliche
Hi everyone
