Magic Remote voice command uses only Youtube everytime
By RJ Fischer
By Lee Magee
By Will M
By David Joseph
Andieboy
Hi all,
I have a 65UM7100PLA with the magic remote. It works fine, except the voice command. Everytime I say something, it open youtube responses.
On the official LG webpage I can see, that it can be used as control the TV itself. "Open picture settings",, "volume up", etc. But if I say that, it opens up youtube, and offers me videos about opening picture settings on offtopic devices.
What am I doing wrong? How to set the voice commands to work on TV itself?
thx!
