    • By Jack1151
    • By wallyricks
    • By MNHL
    • By Matt Moran
      Matt
    • By Kemal Sözüner
      I recently bought a LG TV with WebOS version 8.1 and have a frustrating issue.
      I have a usb disk with all my family photos & videos archive in it.
      We love to browse through the pictures and videos on big screen.
      But current LG TV media player displays either pictures or videos. I want to see them in the order they were captured.
      It would be great to enable this feature when "Photos & Videos" filter is selected.
