Smart TV Lost Channels and Regional
I have a 2019 65" smart tv
when we re tuned all the stations were there no problems then updated as you do when channels move.
Now my tv shows channel 1- 2- 9 10 -11 etc
3 4 5  6 7 8   are all missing they are there in 103 104 HD tv but not in my region
when watching the regional news it is now Granada not our usual station which was there previously.
I have gone to settings and location both are correct to my address.
all the other TVs are receiving my region with no issues so its not an Arial /signal issue
I am using a digital Arial
How do I get my region correct
How do I get  my channels back
Cheers if you can help.
2 hours ago, George Hofmeister said:
Hi @Coppertop
Undertake another retune, at the end of the cycle you should be informed that you have overlapping regions.  Selection the correct options should hopefully cure the problem.  I am guessing that you are in the UK and have Freeview.
Hi George yes UK no option for overlapping regions after return still same missing channels and incorrect region.
Cheers
Keith
    • By Will M
    • By Lesbo
    • By Rex G
