  • 3 weeks later...
  • 7 months later...
On 2/7/2020 at 10:08 PM, Shrek Gee said:
Just got LG smart TV,  but cannot  find Gaana app sadly.  Hope Gaana makes it available soon.
Spotify and amzon music are available on lg content store as of now. Hope gaana app will also be available
  • 6 months later...
But there is an alternative way to enjoy Gaana music on LG device. That it to use the
to download Gaana music offline and add them to LG TV for listening. And to play Spotify music on LG TV, sometimes I will use the to download Spotify music offline and put them on LG TV for playing. If you're interested in them, then you can go for a try.
  • 3 months later...
My suggestion is that you can just download those Gaana music to a USB and then connect it to your LG smart TV. For this method, you can also transfer other music trakcs to your USB drive.  If you want to apply Spotify, you can try to download them with
. Once downloaded, you can then freely enjoy them on your TV.
