Subtitles are garbled when using SmartShare
Subtitles look fine when I watch these video files on my computer. When I watch them on the TV, the text is all garbled with weird Arabic characters and other meaningless random symbols. I have the language set to English and I have tried all the different Roman fonts. What is going on and how do I fix this? I specifically got this TV so I could watch video files off my hard drive, but how can I watch samurai movies if I can't understand what the samurai are saying?!
The native player is a bit primitive.
The best way is to set up a simple server on your computer and a player on your TV. There are a few examples buy I use Plex. The LG App works great and setting up the server is not to difficult. Subtitles are much better supported.
Good luck.
    • By wallyricks
    • By murastefano
      How to show video cover art on  SmartShare on WebOS ?
      I have many movies, mp4 or mkv file with cover art muxed,  but SmartShare
    • By JamieG
    • By MURAD
    • By leodavid
      I've recently purchased a WebOS TV UK6400PVC and magic remote came with it. The software version is 4.10.30.
      The buttons work fine but for some reason, I can't get the cursor to appear on screen.
      Appreciate the help. Thanks
