Converting LG Video Recordings to AVI or MP4
Hello there,
Im quite perplexed. Im pretty well versed in IT and computers but can someone help me out here.
How the heck do I convert a recording from my LG Smart 4K TV into AVI or MP4 to play on my PC or in my car.
Its only video files at the end of the day.
Suggestions PLEASE.
Perplexed LG User
5 answers to this question
43 minutes ago, TomCody said:
Thanks for the information.
I am using this feature to convert old VHS recordings and I's impossible to convert them to any standard video format???
Thanks,.
No, you can not do that.
You need something like this:
 to grab video to a computer. These converters are not very expensive.
Hi, to convert LG video to AVI or MP4 or any other format, you need a video editing tool. If you are a beginner, I share Joyoshare Media Cutter. This is a combination of video converter, cutter, merger and editor available to both Windows and Mac. Importantly, it supports almost all video formats and portable devices including various smart TVs. For the conversion, it gives 2 modes. With the high-speed mode, you can convert videos without quality loss. It is easy-to-use and cost-effective, and gives 5-time free use without limits.
    • By murastefano
      How to show video cover art on  SmartShare on WebOS ?
      I have many movies, mp4 or mkv file with cover art muxed,  but SmartShare
    • By pivotCE
      Tools for the Job
      – Needle nose pliers/tweezers
      – Flush cuts
      – Painter’s and kapton tape
      Trim the USB C Board
      Tape the USB C Board
      Where To Get Power and Data
      Put the Pieces Together
      Congrats, You Now Have USB C
      #webOS4ever
      In its mission to share the message of Life’s Good, LG
      link hidden, please login to view earlier this year to infuse more positivity into the social media experience.
      To further ignite optimism worldwide, LG Vietnam officially titled “An Optimism Universe.” The video features Phương Mỹ Chi, a famous Vietnamese singer and an ambassador for LG Vietnam’s local campaign.
      The song is a reimagined version of “A Universe with You (Vu Tru Co Anh),” Phương Mỹ Chi’s hit track which captivated the country’s youth on social media. Now, as the sound of LG Vietnam’s latest campaign, “Power of Z – Spread out the Optimism,” HIT music producer DTAP has remixed the melody with trendy and upbeat elements while retaining the original’s distinctive Vietnamese traditional folk elements. With relatable and meaningful lyrics, the song encourages Vietnamese youth to live in the moment and enjoy every aspect of their lives.
      The music video takes viewers on a journey across iconic landmarks of major Vietnamese cities, inspiring the younger generation to explore everything the country has to offer. Vibrant red hues and dynamic motion graphics jump across the screen for a visually stimulating experience that encourages viewers to join hands in creating a better future from the simple joys of life. In the video, LG Vietnam’s Gen Z ambassador also extends an invitation to tour , a unique space where visitors can experience LG’s most innovative technology through exciting activities.
      “An Optimism Universe” delighted listeners from the moment of release, reaching an impressive 1 million views on YouTube within just 24 hours. The momentum continued, culminating in a total of 18 million views across all platforms in a mere 10 days.
      This theme song debuted at the Uni-tour of Saigon University in Ho Chi Minh City and the National Economics University in Hanoi, where approximately 3,000 students were met with a fun-filled playground of colorful experience zones organized by LG Vietnam.
      The first space, the Optimism Melody zone, presented students with the opportunity to express themselves through karaoke, enhanced by hands-on experiences with the LG StanbyME and StanbyME GO.
      Nearby, the Optimistic Hints of Tarots zone invited students to discover a unique, positive message revealed with a touch on the LG StanbyME screen.
      Students could share their event experience at the Capture Optimistic Moments zone to receive an optimistic framed photo, while the exhibition space at the Wall of Optimism zone showcased the students’ creative ideas to spread optimism to their friends, relatives and the community.
      In an effort to expand the reach of the Life’s Good brand mission, LG Vietnam also aimed to make a tangible difference in the community with practical support. Enriching cultural life and improving education in rural areas, the company joined hands with the Green Summer 2024 Campaign, an annual event organized by the Vietnam Student Association. Launched in 1997, the campaign provides students with leadership opportunities in social initiatives, including building roads, bridges and charity houses, as well as participating in educational programs to eliminate illiteracy and improve digital competency.
      LG Vietnam donated 27 LG TVs to the Green Summer campaign this year, nine of which were specifically designated for a community housing project in Dak Nong province. The remaining 18 LG TVs were given to remote schools to provide better teaching and learning conditions for both teachers and students.
      Vietnam’s “Power of Z – Spread out the Optimism” campaign reaffirms LG’s commitment to connecting with the younger generation and encouraging young people to approach life with an optimistic attitude, create a positive impact on the community and contribute to a better future for all.
      To spread the message to a wider audience, people can also share positive moments from their daily lives as part of LG Vietnam’s social media challenge with the hashtags #LifesGood, #TíchCựcLanToả and #NụCườiLanXa.
      Additionally, LG employees participated in a for the campaign, contributing to a greener learning environment for students.
      LG actively promotes activities and initiatives that create a better life for Vietnamese people through the power of Life’s Good. Through this local campaign, LG Vietnam hopes to spread more joy and happiness, inspiring a brighter future for all.
      Contributed by LG Vietnam
    • By RedNe
      I would like to ask friends in the group, especially someone who uses webos 3.X, to give me Disney+ and Amazon Prime Video *.ipk. many thanks in advance for your help.
      Since CEO William Cho
      link hidden, please login to view of becoming a ‘Smart Life Solutions’ company, LG has made significant changes to various parts of its business and expanded new areas. To celebrate one year since this bold move, the company has launched an advertising campaign showcasing the remarkable progress it has made so far.
      Titled ‘Connecting Spaces and Future,’ the campaign highlights this vision and demonstrates a strong dedication to innovation, aiming to strengthen its reputation as a leading innovator across various sectors. The campaign features videos showcasing LG’s ongoing transformation into a ‘Smart Life Solutions’ company through an ever-evolving product portfolio. Starting July 27, three videos will be released focusing on its mobility solutions, air solutions and more.
      This marks the first LG video campaign to focus on the company as a whole since ‘Digitally Yours’ in 2000. The new video content seeks to underscore LG’s mobility solutions and the unique experiences they offer, as well as AI smart home solutions that provide personalized environments, webOS solutions that connect various devices on a single platform, and the core technologies including HVAC solutions that will drive future industries.
      The mobility solutions video illustrates LG’s efforts to expand home experiences onto the road and deliver unique customer experiences based on three main themes: Transformable, Explorable and Relaxable. It also features the company’s emerging electric vehicle (EV) charging business. The video on its air solutions highlights excellent HVAC technology, including chillers and heat pumps, and a commitment to innovating global solutions that enhance customers’ lives in every space, from residential to commercial.
      This event is in line with LG’s desire to showcase its innovative efforts beyond the home appliance space. By highlighting other categories and sectors it pioneers, LG aims to resonate with younger audiences and establish a youthful, dynamic brand image.
      On the first anniversary of the announcement of its ‘Smart Life Solutions’ transformation, LG is expanding its achievements across three new pillars of growth: accelerating B2B (including vehicle components and HVAC), pursuing platform-based services (subscriptions, webOS-based advertising and content, etc.) and exploring new business areas such as EV charging.
      Notably, after surpassing KRW 10 trillion in sales last year, LG’s vehicle components business carried on in the same form this year by achieving a record-high performance in the second quarter. The company’s commercial HVAC business, which is also growing rapidly, is further diversifying its business portfolio. LG is continuously leveraging its globally competitive HVAC solutions across the entire value chain, from products, technology, production and services, while actively targeting backend industries supporting AI infrastructure, such as data centers.
      Starting this year, LG launched its , integrating AI and digital transformation with the company’s manufacturing and production data. This business undertakes production consulting, develops production methods, equipment and operation systems, and trains production technology personnel. Furthermore, the company expects to secure orders worth approximately KRW 300 billion in supplying smart factory solutions to business clients. Meanwhile, the company is actively expanding its webOS-based advertising and content business from TVs to automotive infotainment, with sales set to exceed KRW 1 trillion this year.
      LG is accelerating its shift from a traditional product-centric business model to a recurring model that continuously generates revenue through intangible, non-hardware businesses such as subscriptions, content and services.
      Stay tuned to to discover LG’s vision in greater detail and get the latest updates on the company’s ongoing transformation into a Smart Life Solutions company.
