Hi there,
I’ve recently been reviewing the merits of installing SAT IP in my home.  one of the major things that’s stopped me so far is manufacturers such as LG not building applications into their OS to support it.
With SAT IP, you can distribute live satellite content around your home, without having to rely on an internet connection.  This makes sense as it uses existing existing dishes pointed to Astra 28.2e , just stick a SAT IP LNB and replace the coax cable with CAT6 or CAT7, plug into your switch or router and away you go.
This would be a MASSIVE win for LG to include this in future and existing TV units.  Please can someone let me know if this is in development?
    • By The Old Man
      Hey LG
      Yes I am NOT happy
    • By JamesH
    • By skan
      It is shameful that LG has removed support for DTS audio.
      You can request LG to reenable it at change.org:
      change.org/p/dts-dts-x-passthrough-support-for-2021-2022-lg-oled-tvs
    • By Kula
      How can i delete the Accuweather widget and set the Fireworks color Screensaver again?
      Tnx
      Best Regards
      Dragan K.
    • By pawan sachintha
      I want to play subtitle in sinhalese ....but it isnt on webos video player...how to add a new language on tv....
