7 answers to this question
Did your previous TV tune ok at this address. Can you try taking it to someone else's property with a known good signal to see if it tunes ok there? If it tunes ok there it must be s problem with the Arial or Arial cable or an amplifier or distribution system has failed.
    • By Will M
    • By Lesbo
    • By Rex G
    • By Mogens
      Kind regards
      Mogens
    • By Annie Yazbeck
      I can't find the Spotify app on the LG Content Store. When I search it, there is no result. Anyone can help me to get Spotify on LG Smart TV? I tried to use DRmare Software to download Spotify songs to USB flash drive and play them on my LG Smart TV offline for free. But I prefer to use it via the Spotify app directly.
