US apps in Europe
With VPN I can access the American TV-networks and stream content. I do have a proper account to access this.
Is there a way to get the XFINITY webOS app and install it manually from an USB-stick? It would be a lot nicer to get it directly in my SmartTV than watching over a computer to the TV. As I'm in Europe the webOS store only show European stores.
thanks
    • By thewookiewon
    • By Pranay Mokida
    • By MNHL
    • By Tobin
      Tobin
    • By Luka Pantsulaia
