Do u think I can install webOS? If so, which version?
Hi there, I Have this smatrt TV (model 39LN5700-SA --
I wanted to do something so I can use spotify...I don't think they will ever make it available.... Do u think I can install webOS? If so, which version? Thanks in
Hi @Everton Bazarim
I am afraid that the answer is no you will not be able to install webOS on your TV.  The 39LN5700-SA runs NetCast the predecessor to webOS and the hardware is not supported by webOS.
    • By anna groove
