HBO GO not found in LG Store
I went to add HBO app to my LG TV (50UK6300PUE) with the latest WebOS. I searched for "HBO" and found nothing?
I am located in USA
Is it there and I am missing it somehow?
3 answers to this question
My C7 WebOS is old and lacking. I gave up and bought an Nvidia Shield Pro 2019.  Works perfectly.  FireTV, Roku, AppeTV are other more up-to-date options. For a $3k TV you'd think they would support it longer.
    • By Bhanu Kumar
    • By Ahmad Baeisa
    • By akhil7j
    • By Puja aingh
      Dear LG Team
    • By OKtay Sa
      Hi there,
      i have an 65oled9flb (webos).
      Any one an idea?
      Greets
      Oktay
