APP error messages 🤬
My LG smart tv has stop letting me view All4 & Now tv. I can use these on my iPad. Internet checked and all ok. I’m not a techy and need help please 😊
    • By Marko00
      I've boughtĀ OLED55CX3LA and have screenshare errors ever since.Ā
      I'm using DellĀ machine with Windows 10 onboard.
      only with cancel button.
      Sometimes there is approval button but mostly I have only "cancel" option.Ā
      Have this error onĀ OLED55CX3LA and one older model. Same behavior.Ā
      How to fix it?
      Ā
    • By leader6234
      Hey guys !!!
      I have a UHD UJ634vĀ  LG webos TvĀ  that lately an error message pops on the screen staying : Tv signal has been lost due to the satellite LNB short.Check LNB connection"
      This is really getting on my nerves because I can't get any signal even after resetting the TV or even updating to the lastĀ  software version.
      Here is the actual error message on the right top o the screenĀ
      Thanks in advance !!!
    • By Muser
    • By geoffHome
      Reset our router (turn off then turned on againĀ  and waited) but now no networks are even found to attempt to connect to.
      Any suggestions what my next step should be?Ā  This has happened suddenly.Ā  Thanks
