gigabit on a smart tv
By Will M
By Lesbo
By Rex G
By Mogens
Kind regards
Mogens
By Annie Yazbeck
I can't find the Spotify app on the LG Content Store. When I search it, there is no result. Anyone can help me to get Spotify on LG Smart TV? I tried to use DRmare Software to download Spotify songs to USB flash drive and play them on my LG Smart TV offline for free. But I prefer to use it via the Spotify app directly.
amacias47
can I use the Cable Matters Adapter USB Ethernet USB 3.0 on my lg oled c9 series tv. even if im using a 10/100 mps fast port switch, and plug it in to 1 of my fast port ethernet plug in and will i get the same result?(meaning as if i were to plug it in directly from my ethernet cable and straight to my tv?)'\ wand where do i dpwnload the app to check the speed of usb cable adapter...thankyou all in advance....
3 answers to this question
