4 answers to this question
On 3/10/2020 at 5:47 AM, SamualSS said:
AudFree
is suitable for you to control Spotify on LG Samrt TV. The  tool can help you save Spotify music and send them to the TV for offline playing. You can get more detail on the .
LOL this is not Windows OS.
Hey, if you want to use
, then here is a better way for you. You could use the to save Spotify songs as local files on the USB stick. Then put the USB stick with Spotify songs to your LG TV, then you can play Spotify music on LG TV directly without Spotify app.
By the way, there is a for you to get this tool at less cost. Just go and learn more.
You can just download your preferred Spotify playlists to your computer with the help of
, and transfer them to your USB drive. Then you just need to insert it to your LG TV for offline streaming, also connect your TV to your computer directly is a good way.
    • By Raicho
      Hi, so the spotify app doesn't appear on LG TV LF630V with Bulgaria selected in the settings.
    • By anna groove
    • By Annie Yazbeck
      I can't find the Spotify app on the LG Content Store. When I search it, there is no result. Anyone can help me to get Spotify on LG Smart TV? I tried to use DRmare Software to download Spotify songs to USB flash drive and play them on my LG Smart TV offline for free. But I prefer to use it via the Spotify app directly.
    • By Bella Lee
    • By Pagy
      Hello, ive got LG 55UF7787-ZD and i dont have available Spotify on it. I tried everything, even upgrade firmware by hand, but nothing helped to get it available for me. If somebody has some solution how to install an app to the TV, please let me know. I am not interested of some tricky crazy converting of albums and downloading it in advance. I am really looking for solution to have installed application in my TV, thank you.
