Cyberflix TV Apk Download Updated Version For Android ,PC And Firestick !
By NaveenKumar
Latest version of sun NXT app version 8.0.20 is not working for web os Tv version 4.4.2-11 plz do the needful full & Airtel Xstream is not found in your web os platform kindly check on that too
By majorusa
- 3.23.24 - Romania- 47LB730v
By Steve D B
Hi, my LG webOS TV TN520S is running software version 05.45.45 and since then the channel 4 and channel 5 apps are broken. You can start to watch a program but as soon as the first set of adverts start, the app just loops and you cant progress past the adverts. I a wondering if this is because the TV is running the latest version of its software (I've searched for newer versions but none are shown). Has anyone else had this problem and is it possible to install a previous version of the TV's software to see if this resolves the problem.
By Ali Zia
By Burkey
hi all. new to this but really stumped!!! i live in ontario canada and have been using cogeco cable for internet and tv. it got way too expensive so i cancelled both and switched to bell 3.0 which is at least 3 times faster and we have no tv package, so we are just streaming everything for 1/3 the price!!!!! i signed up for a couple of sports sites, tsn and sportsnet + so i can watch hockey playoffs and other sports. tsn works just fine on the tv. however, sportsnet + says that i have to have web os version 89 or higher. i found my tv, which is a 2023 version, is only version 87!!! i chatted with tech support and they were no help. anybody got any ideas as to what i can do for this??? no auto software updates for it and nothing on the lg app store. quite confused how a 2023 model is not up to date, or sportsnet+ is that far ahead and not backward compatible>>>
thanks to anybody that answers.
dave
