TV dead after OS update
By mean2
By OliverRC
By Ajothen
By Roy Brown
By atcronin
PSM
My TV 55UJ75 was working great till I updated the OS an hour back, and since then has not come on.
It is totally dead as of now. Has this happened to anyone else ?
My advice would be much appreciated.
