On 3/22/2020 at 11:01 AM, Andrea Mastellone said:
Where? Here in Italy is still not available.
Here in Italy is available from yesterday 3.24.2020 when they update the firmware before release the Disney+ app.
My LG65EPLA now works with a 05.10.45 firmware.
The problem is that Disney+ worked fine till yesterday and now seems frozen on before the login screen.
Quote
Try to reinstall the app. I had a similar issue with Amazon Prime Video that I solved in this way.
here in Italy my C955PLA is still on 04.71.05, no new updates
TV can't find any new update, I'll update it manually using a USB device
Updates are pushed at different times. Maybe you want to wait till the update is available via OTA? Instead of doing this manually?
  • 4 months later...
Where did you find version 5.0?
I have a 55C9PLA but I can't find that firmware nor manually or via OTA...
    • By SHawk
    • By Sqwazy
    • By majorusa
      - 3.23.24 - Romania- 47LB730v
    • By сергей фролов
    • By SailorMoon
