  • 2 weeks later...
I solved this issue by simply purchasing an Amazon Firestick 4K.  While it doesn't support Dolby Atmos* on Netflix, it does on some Prime selections. It  supports Dolby Vision*, too (like your OLED) and it works seamlessly. It has nearly unlimited apps available, including HBO NOW, and has twice as much storage (for apps) than your LG TV. I like mine so much, I purchased a second one on Prime Day at half price for my road trips. Once you register it with Amazon, you can stick it in any TV with an HDMI input.  Hope this helps!
Mr. Black
* HBO currently only streams in HD 5.1, so this is not an issue for your question
Link to comment
Share on other sites
